VHM
Jun 20, 2019Aspirant
ORBI AC2200 AP mode
HI, I am using ORBI AC2200. When i configured as AP mode at the master router, can I use the "internet" port as one of the L2 ports to connect upstream? Somehow it works but its not stable. The Wifi...
- Jun 21, 2019thanks. i try again this evening and it works fine with the internet port as l2 uplink now. the wifi is stable. Thanks all
Jun 21, 2019Guru - Experienced User
When i AP mode the WAN port should be connected to tha main host router. The top LED inidicator depends on the WAN port being used. I have my RBK50 in AP mode using the WAN port. Works well.
