VHM's avatar
VHM
ORBI AC2200 AP mode
HI, I am using ORBI AC2200. When i configured as AP mode at the master router, can I use the "internet" port as one of the L2 ports to connect upstream? Somehow it works but its not stable. The Wifi...
  • VHM's avatar
    VHM
    Jun 21, 2019
    thanks. i try again this evening and it works fine with the internet port as l2 uplink now. the wifi is stable. Thanks all
