mecelec
Mar 28, 2019Follower
Orbi AC2200 Install
Does anyone have any history with the use of this satellite on metal buildings. Specifically I am wanting to mount this on the exterior of a pole barn to feed an orbi indoor satelite in the building....
Apr 01, 2019Guru - Experienced User
Anything metal or metallic or concrete structure or building materials will impact wifi signal in general.
The Orbi system is a indoor system only. There is a out door RBSY model that can be placed outside. If the building is of metallic materials, any signal from the outsite wifi source will not pentrate thru the materials well to the inside of the building.
mecelec wrote:
Does anyone have any history with the use of this satellite on metal buildings. Specifically I am wanting to mount this on the exterior of a pole barn to feed an orbi indoor satelite in the building. I was wondering if anyone had tried this with either good or bad results.
