Suz96707
Sep 11, 2021Aspirant
ORBI AC2200 Micro Router RBR20 not working after power outage
Router was connected to a Spectrum modem. After power outage, router no longer accessed internet even though modem has internet access. Reset, unplugged and resynched but nothing works. Spectrum rout...
Sep 12, 2021Guru - Experienced User
What modem do you have?
You put "spectrum router works fine".
Are you going modem---->spectrum router---->orbi?
what actual setup do you have? (with device models)
- Suz96707Sep 12, 2021Aspirant
I have a Spectrum modem. I had the Orbi22 router connected to the modem prior to the outage and all was good. I purchased the Orbi so I could have a signal extender to reach a device in my detached garage. After the outage, the Orbi flashed pink and was not accessing the internet. The wifi worked and all my devices showed connection to the Orbi network, but no internet. When I contacted Spectrum, they said the modem showed internet access but the router wasn't picking it up. I disconnected the Orbi and called to have Spectrum help me connect the Spectrum router, which worked fine. The technician told me I could connect the Orbi router to the Spectrum router if I wanted to use that, but when I connect it, the Orbi flashes pink and there is no internet going through that network. I tried resetting it, I tried disconnecting the power for two minutes, but nothing changes.
- FURRYe38Sep 12, 2021Guru - Experienced User
I took a photo of the bottom of the Spectrum modem. I don't know the model. Similarly, I don't know the model of the router from Spectrum but can send a photo. I can only attach one photo to this message.
- plemansSep 12, 2021Guru - Experienced User
If you're connecting your orbi to your spectrum router, you'd either need the Orbi in access point mode or you'd need to put the orbi's ip address into the spectrums DMZ.
And like FURRYe38 says, to add a photo, click on choose file. If you add it the route you did, a moderator has to approve it and it can take a while.
Thanks for this. I tried adding a file, but could only add one picture. I have a number for Netgear and Orbi support that the Spectrum tech gave me so I will try calling tomorrow.
