dja2k
Jul 03, 2020Aspirant
Orbi AC2200 RBR40 & RBS20's Speed Question
So I had Spectrum standard 200mbps (Speed Test 230's) and upgraded to their ultra 400mpbs package which hasn't fully taken effect yet. Will this Orbi AC2200 system get me at least low 300's to mid 3...
- Jul 04, 2020
Yes, the Orbi system can handle those speeds.
dja2k
With 200 plan I get 230's via ethernet and about 180's at the farthest satellite. I want the increased speed via ethernet on the Router RBR43.
CrimpOn
Jul 03, 2020Guru - Experienced User
Maybe someone who owns this specific model and has a high speed connection will comment. (That's a pretty specific requirement, so I am not optimistic.)
I may be wrong, but I believe Spectrum will let you change back the next month because the change to your account is a software setting. (No change in equipment required.) As our Dear Leader said, "what do you have to lose?"
