dja2k
Jul 03, 2020Aspirant
Orbi AC2200 RBR40 & RBS20's Speed Question
So I had Spectrum standard 200mbps (Speed Test 230's) and upgraded to their ultra 400mpbs package which hasn't fully taken effect yet. Will this Orbi AC2200 system get me at least low 300's to mid 3...
- Jul 04, 2020
Yes, the Orbi system can handle those speeds.
Jul 04, 2020Guru - Experienced User
Did you power OFF the ISP Modem for 1 minuted along with the Orbi system then back on with the modem first the the Orbi system?
What are you wired speeds with a PC connected to the modem, then connected to the back of the RBR using Ooklas installable speed test app?
dja2k wrote:So I had Spectrum standard 200mbps (Speed Test 230's) and upgraded to their ultra 400mpbs package which hasn't fully taken effect yet. Will this Orbi AC2200 system get me at least low 300's to mid 350's? Thanks
- dja2kJul 04, 2020AspirantSorry i wasn't clear, the 400mbps Ultra speed isn't fully activated because i need a newer modem. Currently on my end and theirs, I am tapping out at 230mbps.
I just wanted to know if the Orbi AC2200 can handle more than the rated "best for 200mbps Internet plans" thing om the box. It is running the latest firmware 2.5.x.x.- FURRYe38Jul 04, 2020Guru - Experienced User
