Andrep05
Mar 10, 2020Follower
ORBI AC2200 Resource CD Faulty
I have just unpacked my ORBI AC2200 and the resource CD is faulty. Please advise how I can download a new Resource CD
- Mar 10, 2020
You'll probably have to ask NG support for another. Doe it not work at all in a different PC?
You don't need it to setup the Orbi system. You can use Orbi all or use a wired PC connected to the RBR and web broswer to setup the system.
Mar 10, 2020Guru - Experienced User
