timanghar
Jun 24, 2020Aspirant
Orbi AC2200 Tri Band RBR-40 w/2 RBS20's
I have the Orbi AC2200 Tri Band Mesh system with 2 RBS20's. I had an older nighthawk router before this. I had no issues with the nighthawk but wanted to upgrade and extend my wifi range with the mesh system since we built a barn which is right beside the house. Since switching, our wifi is actually worse. We no longer have wifi in our garage or on our back porch with the mesh system however with the older nighthawk we had internet all over our house and outside on our porches and even all the way to our gate. I'm wondering if it is the mesh system, or is it in how I have it setup? The wifi connections are now very spotty and in/out, not as extended as they were with just my nighthawk router, and really I feel as though I wasted $350 on a system that doesn't work and I can no longer take back since I'm past my return period. I have chatted with support through the iPhone app and did troubleshoot but nothing changed. Does anyone have any suggestions? Reviews I have read say this system should give me service in my barn, but I can't even get service from one room to the next even if I'm sitting right beside one of the satellites. Right now my MacBook is connected to the main RBR40 even though it is literally sitting 1 inch away from a RBS20. Same thing with our phones, they won't connect to the different satellites or router as you move through the house. They stay connected to just one. It's like the system is not "meshing". They're each acting as stand alone wifi units but devices pick and choose which one they want to connect with even though they aren't connecting to the closest one. I greatly appreciate any help or advice in trying to get this system up and running correctly or if you know if I can send it back to Netgear for something else. I'm ready to unplug this and go back to my old nighthawk that was working better than this upgraded system. Thanks!
I would remove the check box and apply the setting. The RBR will reboot. I would power OFF the RBS for 30 seconds then back on.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat is the distances from the house to the barn?
- timangharAspirant
What Firmware version is currently loaded? V2.5.1.16
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Our ISP (Cirranet) provides you with a POE device only. It's what I had the nighthawk plugged into and also have the RBR40 plugged in to it now. There is no model or serial number on it. Would it be best to plug my Nighthawk back in and connect the RBR40 to it?What is the size of your home? Sq Ft? Living is 4000 sq ft, under roof (garages) is 5200 sq ft.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. One of the satellites is right around 30 feet from the RBR 40 and the other one is probably closer to 40-50 ft. We have no insulation in the interior walls at all. So just wood framing and sheetrock.https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
What is the distances from the house to the barn? The barn sidewalk and our backporch sidewalk connect. The house and barn itself are maybe 10 feet apart.
- timangharAspirant
Sorry! I answered in color but it didn't add my colored responses.
