timanghar
Jun 24, 2020Aspirant
Orbi AC2200 Tri Band RBR-40 w/2 RBS20's
I have the Orbi AC2200 Tri Band Mesh system with 2 RBS20's. I had an older nighthawk router before this. I had no issues with the nighthawk but wanted to upgrade and extend my wifi range with the mesh...
- Jun 25, 2020
I would remove the check box and apply the setting. The RBR will reboot. I would power OFF the RBS for 30 seconds then back on.
Jun 25, 2020Guru - Experienced User
Be sure to make a backup configuration to file for safe keeping after making sure things are good. Saves time if a reset is needed later on down the road. Under Advanced Tab/Adminstoration/Backup. :smileywink:
