JHanno
Sep 17, 2017Aspirant
Orbi AC2200 vs AC3000 up/down speeds
Hi everyone, Recently I purchased the 3 set Orbi home mesh wifi network and all seemed well. On initial connection I was getting the ~100+ mpbs I was paying for quite consistently. Then connection ...
OrbiMan
Sep 17, 2017Luminary
Rbk50 have the faster wifi backhual between router and satellite
- JHannoSep 17, 2017AspirantA little confused by this, do you mean that the satellite may not be close enough? If so I have put the router and satelite in the same spots as the previous set only exception being im waiting on a second satellite. The connection seems stable the speed is just not the same as the previous set
- DarrenMSep 19, 2017Sr. NETGEAR Moderator
Hello JHanno
What is the firmware version that your orbi is running?
DarrenM
