JHanno
Sep 17, 2017Aspirant
Orbi AC2200 vs AC3000 up/down speeds
Hi everyone, Recently I purchased the 3 set Orbi home mesh wifi network and all seemed well. On initial connection I was getting the ~100+ mpbs I was paying for quite consistently. Then connection ...
JHanno
A little confused by this, do you mean that the satellite may not be close enough? If so I have put the router and satelite in the same spots as the previous set only exception being im waiting on a second satellite. The connection seems stable the speed is just not the same as the previous set
DarrenM
Sep 19, 2017Sr. NETGEAR Moderator
Hello JHanno
What is the firmware version that your orbi is running?
DarrenM
