HolmDK
Jul 02, 2020Aspirant
Orbi AC2200 with 3 satellites
I have had the system for almost 2 years, with 3 satellites it covers the whole house, and until now it has worked perfectly. About 3 munth ago it started to be really unstable, the internetconnecti...
Jul 02, 2020Guru - Experienced User
What modem are you using?
Have you checked your modem signal strengths?
Do all devices have issues, just wireless devices, just wired devices?
Or is it just devices connected to the satellites?
Does it stay stable if you just try running the router (without satellites)?
