HolmDK
Jul 02, 2020Aspirant
Orbi AC2200 with 3 satellites
I have had the system for almost 2 years, with 3 satellites it covers the whole house, and until now it has worked perfectly. About 3 munth ago it started to be really unstable, the internetconnecti...
Jul 02, 2020Guru - Experienced User
What modem are you using?
Have you checked your modem signal strengths?
Do all devices have issues, just wireless devices, just wired devices?
Or is it just devices connected to the satellites?
Does it stay stable if you just try running the router (without satellites)?
HolmDK
I have checked the modem signal strength, and its perfect.
Its only the wireless devices which have issues, the wired are perfect.
I will try without satellites.
/Jan
- plemansJul 02, 2020Guru - Experienced User
You can also try enabling/disabling:
Fast roaming
Beamforming
daisy chain (unless you're using daisy chain and need it)
- HolmDKJul 06, 2020Aspirant
I have enabled fast roaming and Beamforming and testing the last days.
It works good when I have only one satellite connected. If I turn one one of the others it becomes unstable, which I dont understand.
- FURRYe38Jul 06, 2020Guru - Experienced User
Is Daisy Chain enabled?
HolmDK wrote:I have enabled fast roaming and Beamforming and testing the last days.
