HolmDK
Jul 02, 2020Aspirant
Orbi AC2200 with 3 satellites
I have had the system for almost 2 years, with 3 satellites it covers the whole house, and until now it has worked perfectly. About 3 munth ago it started to be really unstable, the internetconnecti...
HolmDK
I have checked the modem signal strength, and its perfect.
Its only the wireless devices which have issues, the wired are perfect.
I will try without satellites.
/Jan
Jul 02, 2020Guru - Experienced User
You can also try enabling/disabling:
Fast roaming
Beamforming
daisy chain (unless you're using daisy chain and need it)
- HolmDKJul 06, 2020Aspirant
I have enabled fast roaming and Beamforming and testing the last days.
It works good when I have only one satellite connected. If I turn one one of the others it becomes unstable, which I dont understand.
- FURRYe38Jul 06, 2020Guru - Experienced User
Is Daisy Chain enabled?
HolmDK wrote:I have enabled fast roaming and Beamforming and testing the last days.
Daisy Chain is enabled.
The distance between the router and satellite is 50 feet. - and this setup works witg 5g.
from the satellite there is only about 20 feet to the next satellite which is in the cellar - if I turn it on the problems begins, when it is off it is not the whole cellar which is covered.
the 3.rd satellite is about 30 feet from the router - but in between the router and the one 50 feet away.
The setup has been working perfectly earlier.
