HolmDK
Jul 02, 2020Aspirant
Orbi AC2200 with 3 satellites
I have had the system for almost 2 years, with 3 satellites it covers the whole house, and until now it has worked perfectly. About 3 munth ago it started to be really unstable, the internetconnecti...
Jul 02, 2020Guru - Experienced User
You can also try enabling/disabling:
Fast roaming
Beamforming
daisy chain (unless you're using daisy chain and need it)
HolmDK
Jul 06, 2020Aspirant
I have enabled fast roaming and Beamforming and testing the last days.
It works good when I have only one satellite connected. If I turn one one of the others it becomes unstable, which I dont understand.
- FURRYe38Jul 06, 2020Guru - Experienced User
Is Daisy Chain enabled?
HolmDK wrote:I have enabled fast roaming and Beamforming and testing the last days.
- HolmDKJul 06, 2020Aspirant
Daisy Chain is enabled.
The distance between the router and satellite is 50 feet. - and this setup works witg 5g.
from the satellite there is only about 20 feet to the next satellite which is in the cellar - if I turn it on the problems begins, when it is off it is not the whole cellar which is covered.
the 3.rd satellite is about 30 feet from the router - but in between the router and the one 50 feet away.
The setup has been working perfectly earlier.
You migh try this, swap around the RBS to make sure the cellar RBS works in the other location.
You might disable Diasy Chain to see if this changes any behaviors.
What is happening exactly with the 2nd RBS is connected?
I presume the RBS and RBR are all using same version of FW?
