YancyD
Sep 23, 2020Aspirant
Orbi AC2200
Does Orbi AC2200 Mod #RBK20W-100NAS work with DSL?
Sep 23, 2020Guru - Experienced User
without a dsl modem? no.
if there's a dsl modem/router prior to it? then yes you can connect the orbi to it.
YancyD
Thanks. Do you know if there are any Mesh router/modems available for DSL?
- plemansSep 23, 2020Guru - Experienced User
Orbi doesn't have any with a dsl modem integrated. But you can use your standard modem/dsl router that you have an put it in modem only/passthrough mode. In that mode you can hook up an orbi setup to it
- YancyDSep 23, 2020Aspirant
Again thanks, but I should have asked, to your knowledge does any company make a DSL Mesh Modem/Router?
- FURRYe38Sep 23, 2020Guru - Experienced User
As far as what NG produces, NG has the following MESH products:
https://www.netgear.com/support/product/orbi.aspx
https://www.netgear.com/support/product/nighthawk-mesh.aspx
NG would not know of other router mfrs products or what they support.
You will need to research the other router mfrs product pages to see what they support for DSL modem MESH, if they have any.
YancyD wrote:Again thanks, but I should have asked, to your knowledge does any company make a DSL Mesh Modem/Router?
