KHeilborn
Feb 21, 2024Tutor
ORBI AC300 RBR50/RBS50 fv V2.7.4.24
Hi, When trying to add my iPhone (iPhone 12) as a trusted device in the routers account settings, I get an "Unable to add your device - an internal error occured. Try again" - message when respondin...
- Feb 22, 2024
Hi,
I should have done it from the start, but reinstalling the Orbi app on my iPhone made it work. Thanks for your support đ
Feb 21, 2024Guru - Experienced User
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Your behind on FW as well:
KHeilborn
Feb 21, 2024Tutor
Hi,
Thanks for your support. I've tried the sollutions suggested. Firmware updated on both satellite and router, disabled randomized MAC and IP privacy. But still can't add the device and I'm getting the same error message as before. It's not a big issue, just annoying so a may just skip to add the iPhone as a trusted device
- FURRYe38Feb 21, 2024Guru - Experienced User
What iOS is on the iPhone?
You can set a IP address reservation for the phone at least:
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
Are you trying to add this to the Access Control section of the routers web page?
- KHeilbornFeb 21, 2024Tutor
Thx. I run iOS 17.4 and tried to reserve an IP-address in the router. Still experiencing the same issue though...
Where are you see this message at?
SInce the system is behind on FW, i'd update FW and then factory reset the system and setup from scratch using a web browser and PC: https://community.netgear.com/t5/Orbi-Wi-Fi-5-AC-and-Orbi-with/New-RBR50-RBS50-Firmware-Version-2-7-5-4/td-p/2296598/jump-to/first-unread-messagehttps://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Once system is set up again, you should be able to setup an IP address reservation and also should be able to set up access controls as well.
