mrmattis
Jan 23, 2019Initiate
Orbi AC3000 - Slow wifi, and is getting worse
Hello
I have the following system.
Modem - Bridge.
RBR50 - Routermode - Auto Channel - Last firmware.
RBS - Last firmaware.
Backhaul - Wifi - Good connection.
When connecting with...
- Jan 27, 2019
Thanks for posting back. Glad that you have some beta FW for your RBR50. Sounds like its working better for you. Keep us posted. Hope the new beta comes to the community soon.
Mark your post as resolved so others will now.
mrmattis wrote:
I have installed beta firmware, 2.2.2.20. Seems to be ok now. Last resultat was 478/437 using Samsung S9+ wifi. 2 meters from router. Using cable is full speed, 500/500.
Jan 26, 2019Guru - Experienced User
Any progress on this?
mrmattis wrote:
Hello
Modem - Bridge.
When connecting with cable i get 500/500 from modem and satelitt, and this is what I pay for.
The first day when i connected the system I got about 400/400 on wifi, short distance from the router.
The next day average is about 200/200 short distance from router or satelitt.
I have tried factory reset, and nothing helps.
Beamforming is activated, and the rest is default.
My Aimesh had better performance on wifi, but it was unstable.
Where has my wifi speed gone? Cable speed is 100% up/down, and the system i stable, but slow on wifi.
mrmattis
Jan 27, 2019Initiate
- ekhalilJan 27, 2019Master
mrmattis wrote:
I have installed beta firmware, 2.2.2.20. Seems to be ok now. Last resultat was 478/437 using Samsung S9+ wifi. 2 meters from router. Using cable is full speed, 500/500.2.2.2.20? This is an Orbi Pro software, do you have an Orbi Pro?
I don't think there is yet a beta software for Orbi called 2.2.2.20.
- FURRYe38Jan 27, 2019Guru - Experienced User
