Dronjones
Jul 20, 2020Aspirant
Orbi AC3000 - speed test 700Mbps off router. Max on the WiFi is only 300
Hello all, first thank you to this community for being so helpful. I purchased the setup in the subject above. We are currently on xfinity/comcast. Previously I had the 200Mbps package and was g...
Dronjones
plemans. Thank you, appreciate the response. The speeds I am referring to are even when I’m standing in the same room as the main router. Based on the capable speeds of the WiFi mesh losing half the speed seems a bit much though?
Jul 20, 2020Guru - Experienced User
Like plemans mentioned, wifi speeds will not be the same as wired. Based on wifi conditions, configuration, device design and support, most wifi devices connected on 5Ghz AC mode will max out at around 400-500Mpbs. Even my Mac Book Pro 2018 only sees around 300Mpbs normally. Contact your wifi devices mfrs to see what theoretical speeds they seems to support on 5Ghz AC.
Check the connection rate if your wifi devices as well:
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
