ShankarHokie
Jan 13, 2019Apprentice
Orbi AC3000 + Comcast 400Mbps -- Router reports 487Mbps Cannot get more than 220 Mbps via LAN
Hello,
I have been using the Orbi mesh network and Comcast with awesome results.
I was in the 150Mbps Blast! plan and regulalry clocked > 200Mbps download speeds on my desktop connected v...
- Feb 03, 2019
First - Happy News - I am clocking > 400 Mbps on my desktop with every speed test.
After several factory resets doing nothing, I unchecked the "Enable Daisy Chain Topology". The router did a restart and BOOM my LAN speed went up and the wireless speeds have not suffered.
Not sure what the technical reasons are, but I am happy now.
FURRYe38 wrote:
Possible something on that PC is causing problems.
Hope you find the problem.
ShankarHokie wrote:
Yes. Same laptop. Slow on LAN and fast on wifi.
Now my iPhone, Samsung phone, laptops, report > 300 mbps via wireless, using the Ookla speed test app.
I killed and completely uninstalled the killer app. New sure that there was no other qos from my Dell desktop. Still LAN speed limited to 300 or below.
I guess I'll keep investigating. Not going to the gigabit plan anytime soon! 😏😏
randomousity
Jan 21, 2019Luminary
So, I have a couple suggestions, if you're still working on this. I saw your differential results between ISP > modem > computer compared to ISP > modem > Orbi > laptop.
I propose unplugging the Orbi satellite(s), which will ensure you're connected directly to the Orbi router.
Also, have you been conducting this test wirelessly, or over ethernet cable? Try both ways to see if one or the other is the issue. When you're running the test directly connected to the modem, you MUST be using ethernet. When you're running the test on the computer by way of the Orbi, which are you using (wifi or ethernet)? If you've been testing over wifi, which version network card does your laptop have? E.g., 802.11g, n, ac? And how many data streams does it support? 2x2? 3x3? Are you connected via 2.4GHz or 5GHz? I'm just wondering, since when you test directly from the modem, you use ethernet, and maybe when you're testing via the Orbi you're using wifi, if the discrepancy can be explained by a limitation on your laptop's wireless networking card, which band you're using, etc.
What does it say on the QoS page in the Orbi settings? Did you run that before? If so, maybe it's possible the Orbi is limiting you based on your old connection speeds, and you need to either factory reset the Orbi to clear that, or run it again so it updates with your current bandwidth.
ShankarHokie
Jan 21, 2019Apprentice
All of the tests are done with ethernet connection on my desktop.
I can try and disconnect my satelittes. However, I have 14 devices connected in the network. Will that affect LAN speed, if they all connect to the router instead of the satellites?
- ShankarHokieJan 21, 2019Apprentice
Here's a weird thing!!
Tested with my work laptop. It is a Dell. First tested wireless. Xfinity speed test reported 487Mbps download and 8 Mbps upload. Tested 10 times. Similar results.
Connected the ethernet cable to the laptop. Tested speed. 202Mbps download speed. Same result multple times.
Any thoughts?
BTW, I saw this thread here. I have the same Killer ethernet controller. I had it before this issue started. I have disabled the service, still the same results on my desktop
https://community.netgear.com/t5/Orbi/Orbi-Throttling-Wired-Ethernet-connection/m-p/1639374- FURRYe38Jan 21, 2019Guru - Experienced User
Do the Dell wireless speeds are good and same laptop wired speeds are slow?
If you have same Killer adapter, I would look into any QoS or network traffic management features on these adapters to see if there is someting causing a slow down on the wired side.
Can you test with a PC that doesn't have a Killer adapter installed?
Any thoughts?
https://community.netgear.com/t5/Orbi/Orbi-Throttling-Wired-Ethernet-connection/m-p/1639374- ShankarHokieJan 22, 2019ApprenticeYes. Same laptop. Slow on LAN and fast on wifi.
