ShankarHokie
Jan 13, 2019Apprentice
Orbi AC3000 + Comcast 400Mbps -- Router reports 487Mbps Cannot get more than 220 Mbps via LAN
Hello,
I have been using the Orbi mesh network and Comcast with awesome results.
I was in the 150Mbps Blast! plan and regulalry clocked > 200Mbps download speeds on my desktop connected v...
- Feb 03, 2019
First - Happy News - I am clocking > 400 Mbps on my desktop with every speed test.
After several factory resets doing nothing, I unchecked the "Enable Daisy Chain Topology". The router did a restart and BOOM my LAN speed went up and the wireless speeds have not suffered.
Not sure what the technical reasons are, but I am happy now.
FURRYe38 wrote:
Possible something on that PC is causing problems.
Hope you find the problem.
ShankarHokie wrote:
Yes. Same laptop. Slow on LAN and fast on wifi.
Now my iPhone, Samsung phone, laptops, report > 300 mbps via wireless, using the Ookla speed test app.
I killed and completely uninstalled the killer app. New sure that there was no other qos from my Dell desktop. Still LAN speed limited to 300 or below.
I guess I'll keep investigating. Not going to the gigabit plan anytime soon! 😏😏
ShankarHokie
Jan 21, 2019Apprentice
All of the tests are done with ethernet connection on my desktop.
I can try and disconnect my satelittes. However, I have 14 devices connected in the network. Will that affect LAN speed, if they all connect to the router instead of the satellites?
ShankarHokie
Here's a weird thing!!
Tested with my work laptop. It is a Dell. First tested wireless. Xfinity speed test reported 487Mbps download and 8 Mbps upload. Tested 10 times. Similar results.
Connected the ethernet cable to the laptop. Tested speed. 202Mbps download speed. Same result multple times.
Any thoughts?
BTW, I saw this thread here. I have the same Killer ethernet controller. I had it before this issue started. I have disabled the service, still the same results on my desktop
https://community.netgear.com/t5/Orbi/Orbi-Throttling-Wired-Ethernet-connection/m-p/1639374
- FURRYe38Jan 21, 2019Guru - Experienced User
Do the Dell wireless speeds are good and same laptop wired speeds are slow?
If you have same Killer adapter, I would look into any QoS or network traffic management features on these adapters to see if there is someting causing a slow down on the wired side.
Can you test with a PC that doesn't have a Killer adapter installed?
Any thoughts?
https://community.netgear.com/t5/Orbi/Orbi-Throttling-Wired-Ethernet-connection/m-p/1639374- ShankarHokieJan 22, 2019ApprenticeYes. Same laptop. Slow on LAN and fast on wifi.
I guess I'll keep investigating. Not going to the gigabit plan anytime soon! 😏😏- FURRYe38Jan 22, 2019Guru - Experienced User
