ShankarHokie's avatar
ShankarHokie
Apprentice
Jan 13, 2019
Orbi AC3000 + Comcast 400Mbps -- Router reports 487Mbps Cannot get more than 220 Mbps via LAN
Hello,   I have been using the Orbi mesh network and Comcast with awesome results.   I was in the 150Mbps Blast! plan and regulalry clocked > 200Mbps download speeds on my desktop connected v...
  • ShankarHokie's avatar
    ShankarHokie
    Feb 03, 2019
    First - Happy News -  I am clocking > 400 Mbps on my desktop with every speed test.
    After several factory resets doing nothing, I unchecked the "Enable Daisy Chain Topology". The router did a restart and BOOM my LAN speed went up and the wireless speeds have not suffered.
    Not sure what the technical reasons are, but I am happy now.
    FURRYe38 wrote:
    Possible something on that PC is causing problems.
    Hope you find the problem.
    ShankarHokie wrote:
    Yes. Same laptop. Slow on LAN and fast on wifi.
    Now my iPhone, Samsung phone, laptops, report > 300 mbps via wireless, using the Ookla speed test app.
    I killed and completely uninstalled the killer app. New sure that there was no other qos from my Dell desktop. Still LAN speed limited to 300 or below.
    I guess I'll keep investigating. Not going to the gigabit plan anytime soon! 😏😏
