mvpcurtis
Mar 31, 2020Aspirant
Orbi AC3000 | Help ISP
So I purchased this system and it finally arrived yesterday. I've been trying to connect and and set them up but it appears that when I login to my router which my internet service provider has provided for me, there's no bridge mode. I've searched the web and found that Sky doesn't like their customers to use third party devices.
I paid £300 for this system so I'm wondering if anyone is able to help me out in anyway in successfully setting the system up if it's even possible. Thank you.
Country - United Kingdom
ISP - Sky
Package - Super Fast Fibre
Devices - Sky Q hub (router/modem), Sky Q TV box and a Sky Q mini TV box.
Thank you.
Option 3 would be the easiest for now. Once you understand more about networking and modem router configurations, then you could try the DMZ and router mode on the Orbi.
Enjoy. :smileywink:
You can put the Orbi in AP (access point) mode. it disables the orbi router functions but leaves the wireless and ethernet ports still active to use.
That's how I use my orbi.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
mvpcurtis wrote:So I purchased this system and it finally arrived yesterday. I've been trying to connect and and set them up but it appears that when I login to my router which my internet service provider has provided for me, there's no bridge mode. I've searched the web and found that Sky doesn't like their customers to use third party devices.
ISP - Sky
Thank you.
- mvpcurtisAspirant
FURRYe38 wrote:This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
ISP - Sky
Thank you.
FURRYe38 I'd like to attempt option 2 since there's no bridge or modem mode available within my Sky Q hub so my next question is how do I configure the DMZ?
Thank you.
I would search your ISPs support site or do a web search on your model modem to see where you can configure the DMZ/IP Pass-thru.
I found this:
https://superuser.com/questions/1007399/how-to-set-up-a-dmz-on-a-sky-hub
