mvpcurtis
Mar 31, 2020Aspirant
Orbi AC3000 | Help ISP
So I purchased this system and it finally arrived yesterday. I've been trying to connect and and set them up but it appears that when I login to my router which my internet service provider has provi...
- Mar 31, 2020
Option 3 would be the easiest for now. Once you understand more about networking and modem router configurations, then you could try the DMZ and router mode on the Orbi.
Enjoy. :smileywink:
Mar 31, 2020Guru - Experienced User
You can put the Orbi in AP (access point) mode. it disables the orbi router functions but leaves the wireless and ethernet ports still active to use.
That's how I use my orbi.
