mvpcurtis
Mar 31, 2020Aspirant
Orbi AC3000 | Help ISP
So I purchased this system and it finally arrived yesterday. I've been trying to connect and and set them up but it appears that when I login to my router which my internet service provider has provi...
- Mar 31, 2020
Option 3 would be the easiest for now. Once you understand more about networking and modem router configurations, then you could try the DMZ and router mode on the Orbi.
Enjoy. :smileywink:
mvpcurtis
FURRYe38 wrote:This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
mvpcurtis wrote:So I purchased this system and it finally arrived yesterday. I've been trying to connect and and set them up but it appears that when I login to my router which my internet service provider has provided for me, there's no bridge mode. I've searched the web and found that Sky doesn't like their customers to use third party devices.
I paid £300 for this system so I'm wondering if anyone is able to help me out in anyway in successfully setting the system up if it's even possible. Thank you.
Country - United Kingdom
ISP - Sky
Package - Super Fast Fibre
Devices - Sky Q hub (router/modem), Sky Q TV box and a Sky Q mini TV box.
Thank you.
FURRYe38 I'd like to attempt option 2 since there's no bridge or modem mode available within my Sky Q hub so my next question is how do I configure the DMZ?
Thank you.
Mar 31, 2020Guru - Experienced User
I would search your ISPs support site or do a web search on your model modem to see where you can configure the DMZ/IP Pass-thru.
I found this:
https://superuser.com/questions/1007399/how-to-set-up-a-dmz-on-a-sky-hub
- mvpcurtisMar 31, 2020Aspirant
FURRYe38 Thank you for your advice. I've gone with option 3 for the time being just until I familiarise myself with networking. I'm trying to get into IT you see, more specifically the cloud section but I'm on CBTNuggets and I see networking on there. Again, thank you.
What I've done is turned both the 2.4ghz and 5ghz access points off and enabled the access points option on my Orbi.
- FURRYe38Mar 31, 2020Guru - Experienced User
Enjoy. :smileywink:
