mvpcurtis
Mar 31, 2020Aspirant
Orbi AC3000 | Help ISP
So I purchased this system and it finally arrived yesterday. I've been trying to connect and and set them up but it appears that when I login to my router which my internet service provider has provi...
- Mar 31, 2020
Option 3 would be the easiest for now. Once you understand more about networking and modem router configurations, then you could try the DMZ and router mode on the Orbi.
Enjoy. :smileywink:
mvpcurtis
FURRYe38 Thank you for your advice. I've gone with option 3 for the time being just until I familiarise myself with networking. I'm trying to get into IT you see, more specifically the cloud section but I'm on CBTNuggets and I see networking on there. Again, thank you.
What I've done is turned both the 2.4ghz and 5ghz access points off and enabled the access points option on my Orbi.
Mar 31, 2020Guru - Experienced User
Enjoy. :smileywink:
