nazzoli
Apr 01, 2022Aspirant
Orbi AC3000 / RBR500 Unable to update Firmware (firmware update failure)
I have been having intermittent wifi issues with my Orbi. I went to upgrade the firmware from the app but it says that it failed. Any help with how to update it? Or is it better to just reset the s...
Apr 01, 2022Guru - Experienced User
what firmware version are you on?
What modem/gateway are you connected to?
What "issues" are you having in details? (the more details, the better we can help)
nazzoli
what firmware version are you on? v2.7.3.00
What modem/gateway are you connected to? connected to ATT using there modem PACE 5265AC (all radios are off on this)
What "issues" are you having in details? (the more details, the better we can help) Periodically my wifi seems to drop for a few seconds and then comes back online. Example is that when we are watching Hulu, it buffers for 2 seconds and then the service will come back on. This happens when I am on work calls as through MS Teams as well. My call will drop and tell me that I no longer have connection and then the connection comes back a few seconds later. My work laptop is wired to one of the satellites.
- KevinLiTApr 02, 2022NETGEAR Moderator
Hello nazzoli,
I understand you are having issues with updating the firmware to your RBR50 using the mobile application. The RBR50 can also be manually updated using a computer. Please follow the steps below to update your RBR50 using a computer.
First, Download the updated firmware from the link below then save it to your desktop:
https://www.netgear.com/support/product/RBK50.aspx#download
Then, Navigate your RBR50 log in page by navigating to the following link :
Once you are logged in to the RBR50 follow the instructions below:
- Select ADVANCED > Administration > Firmware Update.
- Click the Manual Update tab.
- Click the Browse button, then locate and select the file that ends in .img on your desktop.
Be careful not to select the wrong file. - Click the UPLOAD button to upload the firmware file.
It takes a few minutes to finish the process.
The page adjusts. - Click the YES button to continue.
- After the Orbi router finishes updating, double-check the firmware version in the upper-right corner.
The firmware on your Orbi router is updated.
(Please ensure first your update the firmware on the satellites then your router)
Please let me know if this helps!
Best,
Kevin
Community Team
- CrimpOnApr 02, 2022Guru - Experienced User
Might want to double check. Netgear has never released a firmware version V2.7.3.00 for the RBR50 router.
Does the Orbi log indicate that the internet connection was lost and reconnected?
- nazzoliApr 02, 2022Aspirant
This is taken directly from orbilogin... looks like i don't need an update, but it still doesn't explain why my network drops out.
Model Name Device Name Current Version Status Router RBR50 RBR50 V2.7.3.22 No new firmware version available. Satellite RBS50 Orbi Satellite-1 V2.7.3.22 - plemansApr 02, 2022Guru - Experienced User
Well the pace modem you're using is a modem/router combo device. And disabling the wifi doesn't disable its routing functions.
It causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
