vincent42
Dec 27, 2020Tutor
Orbi AC3000 and iOS devices connection issues
Hi everyone. Hoping to get some tips on how ot resolve my issue. I have intermittent connectivy problems but only with iOS devices, both iPads and iPhones. No issues with Macbooks or PCs or Samsung G...
vincent42
Dec 27, 2020Tutor
Thanks for your reply. I haven't had issues with the modem - it works great with other routers. It is in bridge mode.
I am on the latest firmware - v2.5.2.4. Orbi says No new firmware version available.
Are you saying that I can reset the router to factory default AFTER having updated to latest firmware? That sounds like it would wipe out the firmware update, no? And why is this recommended? It is a brand new router.
Also, an interesting observation. I did disable the Daisy Chain option since I have only 1 satellite. But this made the performance of the satellite much worse. With Daisy Chain enabled, I get 500 mbps speeds, with daisy chain disabled, I get < 100 mpbs speeds. So I left it as enabled.
Dec 27, 2020Guru - Experienced User
vincent42 wrote:Thanks for your reply. I haven't had issues with the model - it works great with other routers. It is in bridge mode.
What is the mfr and model# of this modem?
NG doesn't always put up more recent FW on the services for Orbi to detect. User are encouraged to look at NG download site for most current versions:
https://www.netgear.com/support/
Are you saying that I can reset the router to factory default AFTER having updated to latest firmware? Yes. That sounds like it would wipe out the firmware update, no? NO! And why is this recommended? It is a brand new router.
Also, an interesting observation. I did disable the Daisy Chain option since I have only 1 satellite. But this made the performance of the satellite much worse. With Daisy Chain enabled, I get 500 mbps speeds, with daisy chain disabled, I get < 100 mpbs speeds. So I left it as enabled. Daisy Chain should be DISABLED for 1 RBS.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
- vincent42Dec 27, 2020Tutor
I don't know. Before I spend time looking it up, may I ask, why is this relevant? I have not had any issues with the Modem.
Interesting. Why would Netgear not make it easy for users to upgrade firmware. It seems like a lot of extra effort to download and then (how?) install manually the firmware. Not very well thought out.
What is the tought behind factory reset? It is a new router.
Well, it should be disabled but when I disabled it the satelllite did not work. There seems to be a disconnect between should and what actually happens.
About 4000 sq ft. But the issues are not distance related. I am only 20 feet from router when the issue shows up.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.Distance between router and satellite is about 30 feet.
- FURRYe38Dec 27, 2020Guru - Experienced User
Some modems have built in routers and wifi. Were only looking to see if this is present or not. Nothing nafarious here.
Sometimes NG doesn't post newer FW versions to there servers for unknown reasons. There are other reasons like region location and such which may cause newer FW version NOT to be seen on some users systems. So its should't be an inconvience for users to check NG download site as well. NG offers these as a alternative method if users are not seeing more current versions of FW on there systems. Or keep whats loaded IF that works for you.
Did you power OFF the RBR and RBS then back ON after disabling Diasy Chain?
v4 seems to be a mixed back of users posting that it work and some that it doesn't work. So you can try to downgrade FW or update FW if you don't think v4 is working well for you.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026- dennism1976Dec 27, 2020Aspirant
FWIW, having similar issues here. We have a lot of apple devices (6 iPhones, 6 iPads, Apple TV's and a Mac) and a couple of times during the day the internet will go down but only on the wifi connected devices. Not on anything that is connected through ethernet cable.
Also on the latest (non-US) version which makes it so that I'm on V2.5.2.4 for the router. Both the satellites are also on this version.
I've turned off security for now, hoping that will fix the problem. I didn't change anything other in my setup, other than 2 port forwards.
