Rensini's avatar
Rensini
Follower
May 27, 2019
Orbi AC3000 compatible with AC2200?
I have an Orbi RBK50 system and would like to expand with an extra satellite. Can I possibly combine this AC3000 system with an Orbi satellite of the AC2200 (RBK20) system or are these not mutually compatible?
Thank you.
Kind regards, Rens
1 Reply
  • FURRYe38's avatar
    Yes. The RBS20 series are compatible. Just the backhaul between the RBS20 and the RBR will only be 866Mb and not 1700Mb.
    Thank you.
    Kind regards, Rens
