Stinky_W_Teats
May 25, 2023Aspirant
Orbi AC3000 generally unhappy
hi, I am struggling with a few issues with wifi on my Orbis: I have six Phorus PR5 receivers (these are hard-wired to an amp which is connected to wired ceiling speakers around the house and al...
- Jun 14, 2023
Final update: I bought the Nintendo Ethernet adapter (above) for all the PR5s and they have been rock solid since.
Given that the MBP does not always appear in the list of AirPlay devices, plus the iPad issue when connected to the Orbi satellite, plus the drop outs on signal on the Orbis, I will lay the blame on the Orbis, but it is not 100% proven.
Done messing with this, and shame i had to throw money at the issues.
Stinky_W_Teats
May 31, 2023Aspirant
One thing mentioned in the AirPlay spec is that it will send a wake-up broadcast for devices that have a sleep mode. I checked the PR5 configs and they are all set to No Sleep. So that is not it.
Stinky_W_Teats
my MBP is back in the list of AirPlay devices on my iPhone. Still on the main Orbi at 2.4. iPhone still on main Orbi at 5G.
WiFi connection does not appear to have changed but something obviously did maybe at upper levels of the stack.
- Stinky_W_TeatsMay 31, 2023Aspirant
MBP is gone again but nothing changed from what i can see.
The only AirPlay device that has consistently shown up since yesterday afternoon is the PR5 that is connected at 5G (kids' bath). It's still there through all the ups and downs of the MBP and other PR5s.
Found an old thread on setting up a grill that required 2.4G that said turning off on 20/40 coexistence fixed an issue (but it didn't mention AirPlay). Given it popped up in a search for 2.4 vs 5 connectivity, it might be worth a shot
Will give it a whirl at lunch since it may cause the Orbi to reboot and don't want to blow the rest of the family off the network.
ok, family gave me the green light to reboot it, and i unchecked the 20/40 coexistence box.
After the Orbi rebooted, i can once again see the MBP and all of the PR5s. will see how long that lasts...
- FURRYe38May 31, 2023Guru - Experienced User
Which Orbi model system do you have? The 20 or 50 series?
What FW version is currently loaded?
What iOS and OSX versions are loaded on the Mac Book, phones and pads?
What model is your Mac Book Pro?
HAH! Not long. i went upstairs to the master bath, and all the PR5s disappeared. the MBP is still there. My iPhone switched to the satellite per the Orbi console screen, and is connected at 5G.
I am pretty convinced that one issue with the Orbis are that when you move from the main to the satellite, something goes wrong with the way they handle broadcasts / mDNS. Or that after a few minutes (or a reboot), the Orbis stop allowing that.
Going back upstairs to grab my phone.
OK, back at my desk. I turned the iPhone's wifi off and hit refresh on the Orbi console but even after several minutes and several refreshes, the iPhone is still showing up as an Attached Device on the satellite at 5G. Wondering if there is a cache that is not being cleared on the Orbi? What exactly is being refreshed if not the list of devices that are actually attached to wifi?
After a couple of minutes, I gave up and turned the phone's wifi back on. the console now shows it connected 5G to the main Orbi. But only the MBP is still the only device showing in the AirPlay list.
hi FURRYe38,
Hardware Version RBR50 Firmware Version V2.7.4.24 MBP is a 2019 16-inch running 13.3.1 (a)
iPhone is a 12 running 16.4.1 (a)
I would update FW and see:
Factory reset and setup from scratch afterwards. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-SystemSet manual channel 1 and 40. 40Mhz channel with only.
Don't enable any Armor, Circle, SPC or Traffic meter after getting setup.
Then you might test with the RBS turned OFF to see of all devices can connect properly to the RBR alone. Rule out any RBS issues here first. Test. Then graduate using one RBS.
I have a 2018 MBP with OSX 13.5 beta loaded and dual booting with OSX 12.x I'll set up my RBR 50 and check which radio it connects too. Been a while since I have used my 50 series. 🙄
iPhone 12 pro max is at same as well, 16.4.1.
thx. yeah, a factory reset was my next step. I already did one on the satellite.
Or just go with a different brand - kind of getting tired of the Netgear stuff TBH. I was having issues with my previous Netgear WiFi router so upgraded to the Orbi maybe 4 - 5 years ago, and it's been a bit flakey since the start. And had an expensive UTM which they administratively bricked to force us to upgrade to another piece of their HW - still a bit miffed about that... And the plug on the Gigabit switch is very sensitive where it goes into the back of the box - if i unplug and re-plug to reboot it, it is 50/50 if I need to fiddle with it to get it to turn on. Maybe after 20+ years of Netgear devices it's time for a different brand
Why use the 192.168.*.100 - 200 block of IPs?
It looks like the cable modem uses the 192.168.0.x network
Also, the neighbors are on the other 2.4 channels so i moved mine to 11. 48 is clear for 5G.
So I fired up NetSpot on the MBP again to verify what channels the neighbors are using, and one of them appears to have moved to 11 for 2.4G as well. I think this is the same router that previously had a conflict when I moved mine to 11. So I moved mine to 6 just now.
I only see the MBP and two PR5s after the reboot to make channel 6 take effect.
Scratch that, one of the PR5s dropped while i was watching the iPhone.
I am not sure if i need to go power cycle the PR5s to force them use the new channel. I would think if a device lost connectivity that it would scan the channels and automatically reconnect if it found the SSID and was able to authenticate. But who knows? Since 2 of them were visible, i kinda think they do this automatically.
- CrimpOnMay 31, 2023Guru - Experienced User
This phenomenon is just "one of those things". Refreshing the web page goes through the router table of attached devices , assembles the information to be displayed, and draws the web page. Things like the Device Name, Device Model, and Device Type are stored in separate tables. There appears to be a separate process which goes through the router connections and updates where things are attached. I have never found documentation for how often this process runs.
But, as you have found, Attached Devices will continue to display a device with obsolete connection information for a number of minutes. Annoying that computers do not behave as we want them to.
I've found that having a smaller IP address pool is less the router has to deal with.
I got this from a different branded router mfr I used to use years ago. Always worked well. So just something I've used for NG and mention for uses who wanna try it. Not required of course. Not everyone has 250 devices on online and at most average is maybe 30-40. Why have a such a large pool size when it wouldn't be utilized fully.
What is the brand and model of this modem?
If your modem already has a built in router, you'd be in a double NAT condition. I would utilize the modems DMZ for the RBRs IP address it gets from the modem.Also, the neighbors are on the other 2.4 channels so i moved mine to 11. 48 is clear for 5G.
Good.
hmmmm, this is interesting. In NetSpot, I see my SSID showing as:
My first question was why is it showing 6, +1 as the channel after I set it to 6? What does the +1 mean? Maybe channel 1 is used as a sort of backup? Or maybe it means channel 6 +/- 1 channel (i.e., some flexibility in case not all devices are EXACTLY on channel 6, maybe a few Mhz off)? (i don't think that really makes sense tho)
Second question is why does the vendor (i.e., first 6 of the MAC) not show as NETGEAR for 2.4G?
So I did a search for the vendor using MAC starting with A2:3D:CF and the mac.lc site says "No company is registered as the vendor for mac address prefix A23DCF."
Not sure there is anything there but adding it here in case it means anything to someone else.
Anyway, I was wondering if the 4 MACs correspond to 4 WiFi antennas. But the AC3000 specs say: Orbi Router (AC3000) : Six (6) high performance internal antennas with high-powered amplifiers. Implicit & Explicit Beamforming for 2.4GHz & 5GHz bands. MU-MIMO capable for simultaneous data streaming to multiple devices. Powerful Quad-Core 710MHz processor.
Yes, Primary channel 6 + 1 is the sub channel the wifi systems uses, something 2,3,4,7,8,9 or 10. Probably 7 maybe. Would need a different wifi scanner to see what channels the Orbi is actually using for the sub channel. Primary channels are 1, 6 and 11.
What are the MAC addresses for the RBR and RBS, same as what you see in the scan app?
Ya, seems like those MAC addresses maybe a Private address that doesn't give actual vendor name.
I would edit out MAC addresses before posting in public forums for security reasons.
>If your modem already has a built in router, you'd be in a double NAT condition. I would utilize the modems DMZ for the >RBRs IP address it gets from the modem.It is an ARRIS DG3450.
I was going to say I turned its WiFi off for security reasons, but after looking at NetSpot again I see it is on. Now remembering the cable co. had me turn it on for troubleshooting speed issues a few months* ago. Given that it is also on top of the racks within a few feet of the Orbi and the PR5s, it is possible there is radio interference (even if it is on different channels). I will turn that back off to eliminate the possibility. Here is its info:
In terms of double NATting, it isn't unusual in larger networks (but it may be the Orbi's SW is not written to deal with it). It might slow down performance, but not sure it would affect things solely on the local WiFI network. i.e., iPhone to Orbi to PR5 all on the same IP subnet (only local addresses, no WAN traffic)
* the PR5 issues have been going on for a longer than that.
Very good question. Short answer is yes, but...
Both the satellite and main Orbis show MACs on 2.4G whereas the connection says it is 5G.
I have seen that general behavior with UNIX systems with multiple physical interfaces, where a network scanning tool picks one MAC to represent the entire machine, so this may not be a big deal if the Orbi console is doing the same thing.
But interesting that the console shows it that way since it knows both endpoints handling the backhaul are on 5G
OK, radios on the ARRIS are disabled but no change - seeing only two random PR5s but no MBP. Both are on 2.4 and on the satellite Orbi
Wait the MBP is back. I think the MBP blip may have been it switching to the Orbi satellite, since that is what it is now connected to at 2.4. So the things that are visible to AirPlay are al on the satellite. I don't think this means anything - so tired of trying to find rhyme or reason to this...
iPhone is on main Orbi at 5G
Including this just for reference: AirPlay uses TCP and port 7000 for discovery
https://openairplay.github.io/airplay-spec/service_discovery.html
If I have a cable modem, should the main Orbi be configured as a WAP vs a router? It is set to router currently.
My previous setup was:
modem ---> UTM ---> older Netgear WiFi router ---> Netgear hub
This was so i could isolate WiFi traffic from wired gear such as a home server I didn't want exposed.
After Netgear kindly admninistratively bricked the UTM and I upgraded to the Orbi, ot looks like this:
modem ---> main Orbi ---> hub
Looking at the diagram on the console where you can select router vs WAP mode, it looks like i am truing to use the Orbi more as a WAP. I suppose I could just connect the hub to the modem's Ethernet port and only use the Orbi for WiFi.
Like I said above, I come at this from a large network standpoint and the way the consumer gear works is kinda foreign.
This may be in terms of Apple TV. Apple's RAOP protocol appears to use UDP MDNS and port 5353.
I have had the PR5 on the network for some time now and notice it responding to MDNS queries for both Spotify and Raop.
I names the PR5 "Office" (because it is in the office). Here's a sample response:
Frame 444: 385 bytes on wire (3080 bits), 385 bytes captured (3080 bits) on interface \Device\NPF_{F233B6E4-BE24-4723-AA85-49E87A7B1E81}, id 0 Ethernet II, Src: Phorus_01:90:d8 (60:b6:06:01:90:d8), Dst: IPv4mcast_fb (01:00:5e:00:00:fb) Internet Protocol Version 4, Src: Office.local (192.168.1.77), Dst: 224.0.0.251 (224.0.0.251) User Datagram Protocol, Src Port: 5353, Dst Port: 5353 Multicast Domain Name System (response) Transaction ID: 0x0000 Flags: 0x8400 Standard query response, No error 1... .... .... .... = Response: Message is a response .000 0... .... .... = Opcode: Standard query (0) .... .1.. .... .... = Authoritative: Server is an authority for domain .... ..0. .... .... = Truncated: Message is not truncated .... ...0 .... .... = Recursion desired: Don't do query recursively .... .... 0... .... = Recursion available: Server can't do recursive queries .... .... .0.. .... = Z: reserved (0) .... .... ..0. .... = Answer authenticated: Answer/authority portion was not authenticated by the server .... .... ...0 .... = Non-authenticated data: Unacceptable .... .... .... 0000 = Reply code: No error (0) Questions: 0 Answer RRs: 1 Authority RRs: 0 Additional RRs: 7 Answers _raop._tcp.local: type PTR, class IN, 60B6060190D8@Office._raop._tcp.local Name: _raop._tcp.local Type: PTR (domain name PoinTeR) (12) .000 0000 0000 0001 = Class: IN (0x0001) 0... .... .... .... = Cache flush: False Time to live: 4500 (1 hour, 15 minutes) Data length: 22 Domain Name: 60B6060190D8@Office._raop._tcp.local Additional records Office.local: type A, class IN, cache flush, addr 192.168.1.77 Name: Office.local Type: A (Host Address) (1) .000 0000 0000 0001 = Class: IN (0x0001) 1... .... .... .... = Cache flush: True Time to live: 120 (2 minutes) Data length: 4 Address: Office.local (192.168.1.77) Office.local: type AAAA, class IN, cache flush, addr 2603:8000:403:bd7c:62b6:6ff:fe01:90d8 Name: Office.local Type: AAAA (IPv6 Address) (28) .000 0000 0000 0001 = Class: IN (0x0001) 1... .... .... .... = Cache flush: True Time to live: 120 (2 minutes) Data length: 16 AAAA Address: Office.local (2603:8000:403:bd7c:62b6:6ff:fe01:90d8) Office.local: type AAAA, class IN, cache flush, addr fe80::62b6:6ff:fe01:90d8 Name: Office.local Type: AAAA (IPv6 Address) (28) .000 0000 0000 0001 = Class: IN (0x0001) 1... .... .... .... = Cache flush: True Time to live: 120 (2 minutes) Data length: 16 AAAA Address: Office.local (fe80::62b6:6ff:fe01:90d8) 60B6060190D8@Office._raop._tcp.local: type TXT, class IN, cache flush Name: 60B6060190D8@Office._raop._tcp.local Type: TXT (Text strings) (16) .000 0000 0000 0001 = Class: IN (0x0001) 1... .... .... .... = Cache flush: True Time to live: 4500 (1 hour, 15 minutes) Data length: 129 TXT Length: 6 TXT: tp=UDP TXT Length: 8 TXT: sm=false TXT Length: 8 TXT: sv=false TXT Length: 4 TXT: ek=1 TXT Length: 6 TXT: et=0,1 TXT Length: 6 TXT: cn=0,1 TXT Length: 4 TXT: ch=2 TXT Length: 14 TXT: am=Device1,2,3 TXT Length: 5 TXT: ss=16 TXT Length: 8 TXT: sr=44100 TXT Length: 8 TXT: pw=false TXT Length: 7 TXT: da=true TXT Length: 9 TXT: txtvers=1 TXT Length: 13 TXT: ft=0x00DC0A00 TXT Length: 8 TXT: vn=65537 60B6060190D8@Office._raop._tcp.local: type SRV, class IN, cache flush, priority 0, weight 0, port 5002, target Office.local Service: 60B6060190D8@Office Protocol: _raop Name: _tcp.local Type: SRV (Server Selection) (33) .000 0000 0000 0001 = Class: IN (0x0001) 1... .... .... .... = Cache flush: True Time to live: 120 (2 minutes) Data length: 8 Priority: 0 Weight: 0 Port: 5002 Target: Office.local Office.local: type NSEC, class IN, cache flush, next domain name Office.local Name: Office.local Type: NSEC (Next Secure) (47) .000 0000 0000 0001 = Class: IN (0x0001) 1... .... .... .... = Cache flush: True Time to live: 120 (2 minutes) Data length: 8 Next Domain Name: Office.local RR type in bit map: A (Host Address) RR type in bit map: AAAA (IPv6 Address) 60B6060190D8@Office._raop._tcp.local: type NSEC, class IN, cache flush, next domain name 60B6060190D8@Office._raop._tcp.local Name: 60B6060190D8@Office._raop._tcp.local Type: NSEC (Next Secure) (47) .000 0000 0000 0001 = Class: IN (0x0001) 1... .... .... .... = Cache flush: True Time to live: 4500 (1 hour, 15 minutes) Data length: 9 Next Domain Name: 60B6060190D8@Office._raop._tcp.local RR type in bit map: TXT (Text strings) RR type in bit map: SRV (Server Selection) [Unsolicited: True] - Stinky_W_TeatsMay 31, 2023Aspirant
OK, here is something that finally may be pointing to the root cause. It appears like all signal is lost somewhat frequently, as seen from NetSpot running on my MBP.
The MBP is less than 20' from the main Orbi, 1 floor above (construction is wood with oak flooring). MBP is my primary computer and works very well for anything including zoom and webex conference calls with video, so I would say it has no network issues.
Given the frequent loss of signal, particularly in 2.4G, the AirPlay devices may not be able to re-establish themselves on the network, or they may miss the discovery request, or the iPhone discovery request may be happening during a blip, or etc.
Not sure that would cause that other than maybe an Orbi hardware issue (assuming the neighbors don't hate me and are EMPing the house, but they are super nice so even if they hate me they aren't the EMPing types 😂)
Here's the next few minutes - more 2.4G loss of signal.
Given many of the PR5s are on 2.4G, this could explain it.
hi Netgear: if I could give the 2.4G and 5G separate SSIDs I could fix this by connecting the PR5s all to 5G and wouldn't have these frequent blips to deal with.
Caught him (main 2.4G) in the act!
Why would the satellite's 2.4G signal strength suddenly spike in a good direction?
I have looked at all the usual 2.4G interference suspects like microwave, baby monitors, BT, ec., and nothing unusual is going on when the signal drops to zero
