453Ringo
Dec 13, 2019Follower
Orbi AC3000 mesh network
I recently switched from DirecTv to a streaming service. I have multiple TVs running throughout the house. Some are connected to via WiFi to the cable provider's modem and othjers are connected to th...
Dec 13, 2019Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
