millsy56's avatar
millsy56
ORBI AC3000 RBK Combination star and daisy chain topology
Refer picts attached - Plan A is my current setup which I have great coverage to our granny flat and is directly inline with the Router in the main building however bad to no reception to the shed on the opposite side of the main building. My question, can I add an extra satellite to the shed (Refer Plan B) and enable daisy chain. Will this affect my current excellent signal from the main building to the granny flat. Cheers
1 Reply
  • plemans's avatar
    You can try it. It might work great.
    We can't say 100% how well because there's a ton of variables that can cause interference.
