adamcarley
Aug 17, 2017Aspirant
Orbi AC3000 RBK50 has stopped working with Uverse 5268AC router
I got the Orbi 8 months ago. Initially it was fantastic. The set-up wizard recognized the Uverse router and put the Orbi into AP mode. Performance was great. I turned off the wifi on the Uverse route...
- Aug 24, 2017
Hi Darren,
Yes, I did try that. It didn't work.
Since posting this, I switched back to using the AP mode (but left my AT&T router's WiFi on - not that that should matter). The Orbi Wifi continued to be unstable for 24 hours but then has returned to performing properly.
So I'm fine now but I don't really know why.
Adam
DarrenM
Aug 23, 2017Sr. NETGEAR Moderator
Hello Adamcarley
Did you ever try to shut the router off in the ATT modem and use orbi as the main router?
DarrenM
- adamcarleyAug 24, 2017Aspirant
Hi Darren,
Adam
