adamcarley's avatar
adamcarley
Orbi AC3000 RBK50 has stopped working with Uverse 5268AC router
I got the Orbi 8 months ago. Initially it was fantastic. The set-up wizard recognized the Uverse router and put the Orbi into AP mode. Performance was great. I turned off the wifi on the Uverse route...
  • adamcarley's avatar
    adamcarley
    Aug 24, 2017
    Hi Darren,
    Yes, I did try that. It didn't work.
    Since posting this, I switched back to using the AP mode (but left my AT&T router's WiFi on - not that that should matter). The Orbi Wifi continued to be unstable for 24 hours but then has returned to performing properly.
    So I'm fine now but I don't really know why.
    Adam
