bsw423
Sep 28, 2023Aspirant
Orbi AC3000 (RBR50) is in AP mode, can't connect to internet, can't be accessed via ethernet
Hi, My ISP recently performed maintenance which changed the signal to my internet modem and caused complete internet degradation. After the ISP fixed the issue, which included moving the modem, ...
Sep 28, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
bsw423
The internet modem is a Netgear CM600. I am using a CAT6 cable. Should router get internet from the cable modem if it is in AP mode?
- FURRYe38Sep 28, 2023Guru - Experienced User
No, you'll need to change the RBR back to router mode as the CM modem doesn't have built in router support.
- bsw423Sep 28, 2023Aspirant
That's the issue. I cannot get into the Orbi router. It's not connected to the internet, so can't use orbilogin.com or orbilogin.net. I tried accessing it by connecting the laptop via ethernet to the Orbi and using the default IP - does not work. I tried connecting to the router using the IP address the firewall app displayed for it - does not work. What other options are there to get into the Orbi router? Without getting into the Orbi router, how can I change from AP mode back to Router mode?
Press the reset button in back of the RBR for 15 seconds then release. After the top ring starts pulsating WHITE, use a web browser and navigate to 192.168.1.1
Setup from scratch. Default mode after FR is router mode.
