Faxman
Sep 15, 2021Aspirant
Orbi AC3000 router solid Magenta
After a couple of year of problemless use I have now ended up with a solid purple ring on my router and the satelites. I have one computer connect with a fixed cable to the Orbi router and this comp...
- Sep 16, 2021
I had access to an extra router, did a factory reset on it and my old satelites, and then set everything up again using my old network details. Now my network works again. Not sure if I had a hardware fault, but that would be my guess.
Sep 15, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Faxman
Yes - I have done the 1 min shut off of both the fibermodem and the Orbi router as well as the satelites.
When it comes to firmware I can not check which version I have since I can not connect to the Orbi units with the app. I have not preformed any update over the last 6 months, but I do not know if any automatic updates could have happened since.
My modem that is connceted to the fibre is a Inteno Broadband Technoloy AB, model name XG6846
My unit is a Orbi RBR50 router.
- FURRYe38Sep 16, 2021Guru - Experienced User
To find the FW version, please user a PC or laptop and connect to the RBRs web page at 192.168.1.1 to find the version.
Also your modem may have a built in router. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.Also have the ISP check signal and services up to the modem. The router is dependent upon having a good signal from the modem.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
- FaxmanSep 16, 2021Aspirant
Ok sounds good.
Let us know what the FW version you have loaded is.
Please mark your thread as solved so others will know.
Enjoy.
