Faxman
Sep 15, 2021Aspirant
Orbi AC3000 router solid Magenta
After a couple of year of problemless use I have now ended up with a solid purple ring on my router and the satelites. I have one computer connect with a fixed cable to the Orbi router and this comp...
- Sep 16, 2021
I had access to an extra router, did a factory reset on it and my old satelites, and then set everything up again using my old network details. Now my network works again. Not sure if I had a hardware fault, but that would be my guess.
Faxman
Yes - I have done the 1 min shut off of both the fibermodem and the Orbi router as well as the satelites.
When it comes to firmware I can not check which version I have since I can not connect to the Orbi units with the app. I have not preformed any update over the last 6 months, but I do not know if any automatic updates could have happened since.
My modem that is connceted to the fibre is a Inteno Broadband Technoloy AB, model name XG6846
My unit is a Orbi RBR50 router.
Sep 16, 2021Guru - Experienced User
To find the FW version, please user a PC or laptop and connect to the RBRs web page at 192.168.1.1 to find the version.
Also your modem may have a built in router. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
Also have the ISP check signal and services up to the modem. The router is dependent upon having a good signal from the modem.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
- FaxmanSep 16, 2021Aspirant
- FURRYe38Sep 16, 2021Guru - Experienced User
Ok sounds good.
Let us know what the FW version you have loaded is.
Please mark your thread as solved so others will know.
Enjoy.- FaxmanSep 16, 2021Aspirant
My firmware version is V2.7.3.22
Thanks for the input anyhow.
