Stoic-pillar
Dec 02, 2024Aspirant
Orbi AC3000 Satellite Unable to Connect via Ethernet Backhaul
Orbi AC300 v2.7.4.24 RBR50 - base RBS50 - satellite Hello! I’m confused as to how to setup my base and satellite for Ethernet backhaul. Both are connected to an AT&T modem with WiFi switched off ...
- Dec 02, 2024
Stoic-pillar wrote:
I was hoping to link both the RBR and RBS directly to the modem, in a similar fashion to the documentation.Alas, you are not the first person to reach the wrong conclusion from this diagram. What the drawing does not show is the link between the Orbi system and the Internet. Installation instructions describe connecting the WAN port to the Internet Service Provider. Where should it be?
If only the person creating these drawings had shown the router WAN port connection, people would not attempt a connection that simply does not work.
One suggestion is to try this:
- Move the RBR50 router to the modem location and connect the WAN port to it.
- Place the satellite in one of the other locations and connect it to one of the router LAN ports.
- Place the switch in the other location and connect it to a different router LAN port.
There are still two WiFi devices. There are still Ethernet ports in three rooms.
Dec 02, 2024Guru - Experienced User
Did you plug in the RBS to the back of the RBR and see if they connect. Need to give about 3-5 minutes and the top ring should turn blue.
First make sure the RBS wirelessly connect to the RBR. Once thats done, then ethernet connect them behind the RBR.
Brand and model# of the switch?
Be sure the switch is connected BEHIND the RBR, then the RBS to the switch.
Stoic-pillar
I was hoping to link both the RBR and RBS directly to the modem, in a similar fashion to the documentation. Will this not work? Do I need to acquire an unmanaged switch to do this?
I don’t have a good way of running Ethernet from my RBS/satellite to my RBR/base.
- CrimpOnDec 02, 2024Guru - Experienced User
- FURRYe38Dec 03, 2024Guru - Experienced User
No.
Any ethernet connected RBS needs to be connected behind the RBR so directly behind the RBR or with a switch directly connected to the back of the RBR on one of the LAN ports and then the RBS connected to this switch. Non managed switch is recommended here. NG GS-105/108v4 and GS308v3 work best.
WAN port of the RBR needs to be connected to the ISP modem.
I don’t have a good way of running Ethernet from my RBS/satellite to my RBR/base.- Stoic-pillarDec 03, 2024Aspirant
Thank you all! FURRYe38 | CrimpOn
I have given up on my dream of deploying my modem, base station, and satellite in three rooms linked by ethernet, but what I've got is good enough - my satellite is showing ethernet/wired backhaul in the Orbi settings.
