LanceD
Jan 07, 2020Guide
Orbi AC3000 system constantly dropping Wifi
I've read through this board and have seen a few similar queries, but haven't found any answers to my issues in them so posting this. After much tweaking and fiddling with router and satellite lo...
LanceD
Jan 07, 2020Guide
Thank you for the note. That is indeed how I have the modem and router connected (Xfinity LAN to Orbi WAN). Sorry I wasn't clear about that.
SW_
Jan 07, 2020Prodigy
In that case, disable Daisy-Chain and verify that backhaul signal is within dBM range, between -30dBm and -70dBm, by pointing your browser at http://orbilogin.com/online_upgrade_info.html.
Try forcing Orbi to use static IP address by assigning it an reserved IP address. Here is an example of my AP staic IP/DNS.
