LanceD
Jan 07, 2020Guide
Orbi AC3000 system constantly dropping Wifi
I've read through this board and have seen a few similar queries, but haven't found any answers to my issues in them so posting this. After much tweaking and fiddling with router and satellite lo...
SW_
Jan 07, 2020Prodigy
LanceD wrote:
Here's my current setup:
5) Firmware: V2.3.5.30
Please consider upgrading to the latest FW version v2.5.1.8, which has been stable for my RBK53. More importantly, give Orbi time to settle down once it's been upgraded, typically 24 hours before mucking around with it unless Internet/Wifi stops working post FW upgrade.
LanceD
Jan 07, 2020Guide
Thanks for the detailed info.
1) I am already running with Daisy Chain disabled. Have never enabled it as I have only one satelite. Unless I should give that a try?
2) I am also already running a fixed IP for the Orbi router (which is running in AP mode as noted). This seemed to help with some intital problems of the Orbi dropping offline.
3) I will upgrade the firmware as you suggested and let it settle in; see how that goes.
4) Also, thank you for the tip on monitoring backhaul connection strength. I will test that out also.
- SW_Jan 07, 2020Prodigy
LanceD wrote:Thanks for the detailed info.
No. Daisy-Chain is only required if Satellites are too far from main Orbi. Otherwise, it's a performance penalty.
Nice. Keep it as is.
Yeah - if nothing else, it'll restore Orbi WiFi peak performance.
Circle back with update if possible. Also, please verify which band is affected, 2.4GHz vs 5GH or both.
Here is an example of my current Wireless Settings, which seem to be working well with v2.5.1.8. Might want to download NetSpot to check out WiFi channels congestion. I found that "Auto" works best with 2.4GHz and pick an unused or least congested 5GHz channel. Good luck!
- LanceDJan 07, 2020Guide
Thank you everyone for these very helpful suggestions.
I am going to update firmware (probably tomorrow) and will use the suggested utilities to scan my connection status.
More to come ...
- LanceDJan 08, 2020Guide
Okay ... my Orbi system is now running firmware V2.5.1.8; the update appeared to go well. I'm going to "leave everything alone" for at least a day at let the router and satellite settle in. So far, my devices appear to be attached with strong signals. Crucially, the LG TV has picked up the 5GHz connection, not the 2.4 it so often seemed to prefer until I made changes.
Prior to the update, I re-enabled MU-MINO, set 2.4GHz channel to AUTO, and disabled 20/40 coexistence.
Interestingly ... I did a WiFi diagnostics test using the built-in tool on Mac Catalina, and it informed me the 5GHz channel I was using--44--was congested. It suggested using channel 161. But when I went into the Orbi setup, there are only 4-5 possible 5GHz channels listed (I always throught 5GHz used more like 20 channels?). I chose channel 48 for now--but if there's any way to access higher channels, please let me know.
For now, I'm going to do nothing more and see how this update works. Thanks to all for the suggestions.
