LanceD
Jan 07, 2020Guide
Orbi AC3000 system constantly dropping Wifi
I've read through this board and have seen a few similar queries, but haven't found any answers to my issues in them so posting this. After much tweaking and fiddling with router and satellite lo...
LanceD
Jan 10, 2020Guide
UPDATE - Jan 10
Some progress ... but issues remain.
Since upgrading to firmware 2.5.1.8, I have let things "settle in" and now can report what's up.
At present, all devices are now connected at 5GHz--even the basement Roku that seemed in love with 2.4GHz. So that's a good thing. Also, I spent a full day working in my basement office (on my iMac) without a WiFi disconnect--and that's rare. Speeds are good in the basement, which is one floor below the Orbi sat and about 40 feet away.
Still ... getting disconnects using my Macbook Air in the bedroom, which is only 30 ft from the main Orbi and on the same floor. Speed can't match the basement IMac's signal, either (I get Xfinitiy's promised 200MB/S downstairs off the Orbi sat but only 70MB/S upstairs off the Orbi router--which is running in AP mode). And that signal continues to drop intermittently. Strange that the sat seems to be both more relialbe on connection AND delivers faster speeds and better range than the Orbi router itself.
Current config: 2.4GHz at 25%, channel AUTO, 20/40 coexist disabled. 5GHz at 100%, channel 48. Daisy chain and fast-roaming disabled. Beamforming, MU-MIMO enabled.
Again, all of this is incredibly frurstating, as my former Airport Extreme (running in my old apartment) could reach out at least 40 feet thru walls and was absolutely rock-solid for YEARS with zero tweaking on my part. Meantime, for the past three weeks I've been attending to and tweaking the Orbi network like it's the Space Shuttle about to launch. No way could anyone with zero computer knowledge get this system up and running well. I'm not even sure I'll be able to do it.
The "whole house" coverge claimed simply isn't there for me, and my house is only moderately sized (2400 sq ft or so) and mostly on one floor.
Pretty much out of ideas (other than buying a true mesh system) at this point ...
LD
SW_
Jan 10, 2020Prodigy
Nice update!
The reason Satellite is more reliable is due to its stable 5GHz backhaul back to Orbi. Given Macbook Air is 30ft away and connects to main Orbi, it could be suffering from weak 5GHz WiFi signals. If you haven't already, try restoring 2.4GHz back to 100% and see if that helps.
- LanceDJan 12, 2020Guide
I tried upping 2.4GHz power, but even if I raise it to just 50%, immediately my LG TV latches on to the 2.4 signal and I get vastly reduced WiFi speed--which greatly affects Plex and Netflix viewing. Going back to 25% the LG grabs the sat's 5GHz signal again and all is well. I would kill 2.4GHz tranmission altogether if I could.
At this point, it looks like I'm going to have to put up with occasional WiFi drops in my bedroom in order to have the best-possible (but still not drop-free) connection to my basement iMac and family-room LG smart TV.
Overall, the Orbi system has been a disappointment. It's great WHEN it works, but the lack of a completely reliable connection and the not-up-to-the-hype range (particularly from the RBR base unit) ultimately means, when I can affford to do so, I'll be replacing it with a true mesh system. I'd even settle for slightly reduced WiFi speed (which was one of the reasons I opted for the Orbi) for a more reliable connection and less hassle with IT issues.
No "home" WiFi system should be this challenging to set up, so finicky about firmware, power settings, location of units, etc. Again, while it's hopelessly dated compared with today's high-speed systems, my old Airport Extreme was absolutely effortless to set up (plug it into the bridged modem/router, done!) and rock-solid day in and day out. I NEVER saw a spinning "loading" icon while watching Netflix. Never. With the Orbi ... It's already happened several times.
LD
- SW_Jan 13, 2020Prodigy
LG TV shouldn't have an issue with 2.4GHz, which supports link rate up to 400Mbps at 100% power. With your current 200Mbps ISP speed, 2.4GHz should be sufficient unless it's heavily congested. If 2.4GHz is really congested, get a 2nd Satellite for the MacBook Air location or enable separate 2.4GHz and 5GHz SSIDs.
- LanceDJan 15, 2020Guide
Yes, LG TV can use 2.4GHz and should work that way at 100% power. In THEORY. In practice, the moment the LG acquires a 2.4GHz signal (always from the main RBR), connection drops and TV performance suffers considerably (i.e., Netflix autoplay previews that work perfectly on 5GHz now take forever to load or simply don't work at all). Plex performance (running off my basement iMac server) becomes so slow as to be unusable. The only solution for decent smart TV performance is lowering 2.4GHz to minimum power (25%) so TV always picks up the 5GHz signal off the RBS.
Also, I plan to upgrade the Xfiniity speed (I've sort of inherited the current 200MB/s plan) to at least 500MB/s. Will see how that affects things in general.
As for adding a second sat ... I'm not spending another dime on this Orbi system. As is, the two-unit AC3000 is advertised as "whole house WiFi" for a 5000 sq ft abode. My place is 2400 sq ft at most and the signal is subpar in all but a couple locations (I just had a dropout as I write this!). The other night my wife was in the den trying to watch Netflix on her iPad and the signal dropped so often (spinning buffer) she quit trying to watch her movie in frustration. And the den is barely 25-30 ft from the main RBR! This is pitiul. Does the "5000 sq ft" coverage only apply to houses made of balsa wood?
Today I got an email from Netgear asking me if my issues had been solved (I suppose they can't wait to apply the happy green arrow to this thread). Answer: NO. I have now spent well over a month of almost daily fiddling with the system, trying new router/sat locations, varying power and other settings, dealing with dropped WiFi and rebooting units, etc, etc., etc.
I bought the Orbi system simply to get great Wifi (per many glowing reviews) and, above all, rock-solid performance. Instead, I now have a part-time IT job and none of my WiFi needs met.
- FURRYe38Jan 16, 2020Guru - Experienced User
Possible the wifi adapters in your TVs could be the problem as well. Seen others with issues in these TVs. They seem to prefer 2.4Ghz rather then 5Ghz. Ensure the TVs FW is up to date as well.
You might try another Orbi MESH system or ask about an RMA from NG. See if a different system exhibits the same problem or not. If it does, i would presume it maybe a TV issue rather then Orbi.
- PaulInSFMar 06, 2020Aspirant
I bought the second satellite figuring that would fix my drop-outs. Instead, it's gotten worse. Now I'm regretting not just going with the Xfinity mesh pods. We'll see if I can troubleshoot to make it work better, but I agree that in 2020, a consumer WIFI solution shouldn't be this hard or take this much vocabulary.
- FURRYe38Mar 06, 2020Guru - Experienced User
What Firmware is currently loaded? Ensure both RBR and RBS are using same version of FW.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
PaulInSF wrote:I bought the second satellite figuring that would fix my drop-outs. Instead, it's gotten worse. Now I'm regretting not just going with the Xfinity mesh pods. We'll see if I can troubleshoot to make it work better, but I agree that in 2020, a consumer WIFI solution shouldn't be this hard or take this much vocabulary.
- LanceDMar 07, 2020Guide
PaulInSF ... I feel your pain. Sorry to hear that adding a second sat didn't help (and actually worsened) your setup, but I do appreciate your sharing that info as I was considering that route myself.
I haven't returned to this thread in some time as I've essentially accepted my setup as-is and, for the most part, it's now working pretty well.
Regarding the notes from FURRYe38 ... I have tried EVERYTHING you mentioned at one time or another. I am currently runnning FW v2.5.1.8 on both the base station and the sat. I'm using the base in AP mode; it's attached to a Comcast Technicolor modem with service at 200/20 (I'm going to upgrade that to 1GB soon--and I'll likely dump the rental modem and buy one).
Sat is about 50 ft from the base. I get excellent signal/speed at 5GHz in my basement office (the sat sits almost directly above on the main floor), but my LG smartTV in the family room--about another 50 feet or so from the sat) usually locks onto 2.4GHz. I've tried various channels (Auto and manual settings) for both frequencies. Right now I'm on Auto 2.4 and 48 for 5.
For about three weeks I had almost zero wifi drops--then I stupidly moved the base unti about 8 inches to the left (to get it out of the sun coming thru a window), and suddenly I'd lose wifi 2-3 times a day. Needless to say, I moved it back. It seems to be better now, but seriously can't believe the system is THAT placement-sensitive.
I do have 5-6 other wifi neighbors who I scan for channel use and attempt to distance my setup from. Otherwise, right now I have beamforming on, fast roaming off (dropped all the time with that enabled), coexistence at 40MHz only, IPv6 on, no daisy chain obviously (just one sat), and not using the other features as the base is not in router mode.
All the other questions mentioned I believe I've answered elsewhere in this thread.
For now, I think I can live with what I've got--as long as the drops don't come back (or very rarely). I'm hoping upping my cable service speed will help, too.
LD
- FURRYe38Mar 07, 2020Guru - Experienced User
Possible your buiding materials and envrionment are playing a roll in this. If you moved it a short distance and it got worse then moved it back and got better, this would be some material and envronment causing some of this. What happens if you go in the other direction with the RBS.
What the initial move away from the RBR or closer to the RBR when you noticed it got worse?
- PaulInSFApr 04, 2020Aspirant
Hi,
I'm finally getting back to this.
I have an xFi router from Comcast but it doesn't have a model number on it. Our house is 4200 square feet and I was told a router and 2 satellites would be good for this setup, though I'm regretting not just buying some xFi pods since @ $79 each, they were more cost-efficient.
I can't find the Orbi settings on the app so have not been able to troubleshoot other than moving one satellite about 15' closer. I have just found the Orbi settings on the browser admin and will try some of these settings changes next.
We daisy chain an Apple Time Capsule off of the Orbi router and the odd thing is that the Orbi router often just stops completely, requiring a reboot. When it goes out, the daisy-chained Time Capsule goes out too.
We do have 7-8 WIFI neighbors near us.
Thanks!
- FURRYe38Apr 04, 2020Guru - Experienced User
If your modem has a router buit in, it may have wifi as well. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopPlease try one of the suggestions above with the Orbi RBR.
Has a factory reset and setup from scratch been performed since last update? https://www.youtube.com/watch?v=cMw4ePACgc4
https://www.howtogeek.com/434350/how-to-factory-reset-a-router/
PaulInSF wrote:Hi,
Thanks!
Hi,
Thanks for the quick reply. I've kept the xFi WIFI going since it's sometimes the only working WIFI in the house but will turn it off to test.
When you say do a reset on the router, do you mean the Orbi or the xFi? If I reset, won't i have to reenter all these details again, or does Orbi store the Orbi ones in the cloud ?
Thanks!
- FURRYe38Apr 05, 2020Guru - Experienced User
Yes, try the ISP modems wifi disabled first to see if this helps with the dropping of WiFi on the Orbi. I believe it may.
A reset sometimes is needed as a troubleshooting step. Sometimes newer FW udpates cause problems in pre-existing configurations that become incompatible with newer FW code. Thus a reset maybe needed if users are experienceing problems after a FW update. To save a configuration of the RBR, you can use the backup feature under Advanced tab/Administration/Backup. This will save your current configuration to file for save keeping and saves time. Nothing is saved to the cloud.
Let us know how it goes.
PaulInSF wrote:Hi,
Thanks!
- FURRYe38Jul 02, 2020Guru - Experienced User
Any progress on this? Please let us know.
PaulInSF wrote:Hi,
Thanks!
- MstrbigAug 04, 2020Master
Go to Advanced/Administration/Backup settings, and backup current settings to a file. If you have to perform a factory reset, when you are finished setting up, you can restore that saved file, using the restore function, on above mentioned page. .
