LanceD
Jan 07, 2020Guide
Orbi AC3000 system constantly dropping Wifi
I've read through this board and have seen a few similar queries, but haven't found any answers to my issues in them so posting this. After much tweaking and fiddling with router and satellite lo...
bjvinton
Aug 03, 2020Aspirant
I have the exact same problem. The router is dropping wifi on both PC and Apple products even when right next to the router. Very frustrating. I tried upgrading the firmware. that did not help at all.
Aug 04, 2020Guru - Experienced User
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Press the back reset button for 15 seconds then release.
bjvinton wrote:I have the exact same problem. The router is dropping wifi on both PC and Apple products even when right next to the router. Very frustrating. I tried upgrading the firmware. that did not help at all.
