kenshotx's avatar
kenshotx
Follower
Feb 19, 2018
Orbi AC3000 system testing questions
Where can I see which devices are connected to the router (in my case AP) and which is connected to the AP?  I'd like to test the speeds at each connected device and the connection speed between the two (base and satellite).   So far I'm very happy with the performance.
1 Reply
  • If you connect to the Orbi router with a browser and authenticate you can see the list of connected devices on one of several attached devices lists. That status page shows you what each device is connected to (Orbi router or Satellite) and whether it is connected with 2.4, 5G or a wired connection. Anything on your wired LAN will show as connected to the router with a wired connection.
    The Orbi Android app also shows you the connected devices but you have to tap in the i (Info) icon to see the details including the Orbi that the device is connected to (RBR or RBS).
