vangalkarthik
Feb 16, 2018Follower
ORBI AC3000 Tri-Band disconnects continuously
Hi, My ORBI AC3000 Tri-band system disconnects from the Internet continuously everyday. The performance during the first two weeks was phenomenal. However, it has deteriorated ever since. The firmw...
DarrenM
Feb 21, 2018Sr. NETGEAR Moderator
Hello vangalkarthik
What firmware version are you on? Have you tried to enable beamforming and MUMIMO in the advanced wireless settings? Also have you tried to adjust the wireless channels?
https://kb.netgear.com/25182/Resolving-poor-5GHz-wireless-range-signal-from-my-NETGEAR-router
DarrenM
twander
Feb 21, 2018Tutor
I had this problem too but seems to have stopped being a problem when I switched the router back to the default password. With this change, the router and both satellites have the same PW so when devices move around among the RBK and RBS (which does happen), they connect properly. At least this solved my problem.
Does anyone know how to change the satellite PW, or is this not possible, which seems stupid given my apparent solution to the problem.
