JMerryman's avatar
JMerryman
Orbi AC3000 Tri-band WiFi Router (RBR50v2) and RBK13
Hi - I have an existing Orbi AC3000 system and picked up a new RBK13 system. I was hoping I could just use the satellites in the new system to extend the AC3000 system. Is this possible?
    • CrimpOn's avatar
      CrimpOn
      I believe the question was whether the RBS10 satellites will integrate with the RBS50v2 router.
      My understanding is "no".
    • KevinLiT's avatar
      KevinLiT
      NETGEAR Moderator
      Hello CrimpOn,
      The RBR10 and the RBR50 are compatible with the following Orbi AC Satellites -  RBS10, RBS20, RBW30, RBS40, RBS40V, RBS50, and RBS50Y.
      Best,
      Kevin
      Community Team
      • CrimpOn's avatar
        CrimpOn
        Perhaps I was confused by the Product Data Sheet which says the RBS10 requires an RBR10 (page 4):
        https://www.netgear.com/images/datasheet/orbi/RBS10.pdf
        I doubt that most customers would want to throw out an RBR50 with three user Ethernet ports in favor of an RBR10 which has only one.
        (and satellites that can connect over Ethernet - which the RBS10s cannot.)
