sclawrenc
Nov 19, 2019Apprentice
Orbi AC3000 using Wired Backhaul with Edge Router 4
I'm considering placing the Orbi in Access Point mode using wired backhaul and using an Edge Router 4 as my wired router. Everything is currently working fine with my Orbi, and I'm just wanting to t...
Nov 19, 2019Guru - Experienced User
Yes, AP mode works just fine. Had a ER-X connected at one time with the Orbi in AP mode. Keep the RBS directly connected to the RBR or use a non manged, non green ethernet switch in between the RBR and RBS.
- sclawrencNov 19, 2019ApprenticeThanks. Do you think it’s any faster using a stand alone router like the er4?
- FURRYe38Nov 19, 2019Guru - Experienced User
I would look at the specs of the ER4 router. I know that the ERX router only supports up to around 300Mbps WAN to LAN. I recently updated to 1Gb WAN to LAN so I can't use the ERX router currently. If the ER4 supports your ISP speeds WAN to LAN, can try it and see how you like it. There UI is a bit more complex and not as easy as NGs UI. Meant for the advanced networking users or IT pros.
- sclawrencNov 22, 2019Apprentice
Thanks.
Do you know if my router settings will be saved if I toggle the router from router mode to access point mode? I might try to use the access point mode, but I would like an easy way to change it back to router mode without losing my settings.
I would also think it would not be possible to segment my WiFi guest (IoT) network from my private WiFi network if I'm using the Edgerouter 4 as a router/gateway. Do you know if this would be possible with the Orbi in access point mode?
