Maranzi
Oct 30, 2017Follower
Orbi AC3000 WEP
Hello, I'm considering of purchasing Orbi (AC3000) Wireless to home. At home I have "legacy" home automation system which only can use 2.4Ghz WLAN and WEP Security. Is WEP security possible with Orbi WLAN? Another question: what is recommended way to limit only those home automation devices to access/use the 2.4Ghz / WEP-secured WLAN?
Many thanks in advance for the advice!
//Maranzi
1 Reply
- Streak2Master
There is no WEP option for wifi security on the Orbi.
You would have to have a separate and older router to handle those devices or upgrade those devices.
The Orbi has MAC filtering to allow control of what connects where.
