VNE
May 03, 2019Follower
ORBI AC3000 WITH APPLE 8S WIFI CALLING HAVING BIG PROBLEMS - OTHER PARTY CANNOT HEAR ME
HELP - I just bought an Orbi RBK53 and my Iphone 8s does not work with wifi calling feature - the other party complains of spotty conversation - every other word etc.
We are using a new Ac3000 ...
May 03, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
We are using a new Ac3000 RBK50 with a new ISP providing service over 250 Mbps up and down - the new internet is very fast. I called my ISP and they said nobody else is having this problem - my issue with spotty wifi calling on my iphone 8 on my new orbi ac3000 is isolated to me - no other customers from the ISP are having this issue - the ISP promtes the orbi AC3000 and they have lots of customers using it with zero complaints.
Please help - I want my wifi calling to be smooth on my new orbi ac3000 rbk50.
My old isp had slower speeds of under 40mbps and I used my apple wifi with no problems. The apple wifi can't handle the speeds of my new isp so I bought the orbi.
Thank You,
