RPIvers's avatar
RPIvers
Orbi AC3000 with Cisco SG112-24 Switch
Using a Cisco unmanaged sg112-24 switch with Orbi AC-3000 and with one satellite connected via ethernet backhaul to same switch.  V2.2.1.210 firmware on both Orbi devices.  Orbi router cpu at 17%.  A...
  • RPIvers's avatar
    RPIvers
    Feb 04, 2019
    I happened to have a Linksys 1GB switch without any Green stuff or Loop detection.  It works OK.  I will keep an eye on the network to see is anything changes.  The Orbi CPU utilization is about the same at 17%.  I might be chasing shadows with the Cisco - it likely is thinking it is detecting a loop when none is actually there.
