RPIvers
Feb 03, 2019Aspirant
Orbi AC3000 with Cisco SG112-24 Switch
Using a Cisco unmanaged sg112-24 switch with Orbi AC-3000 and with one satellite connected via ethernet backhaul to same switch. V2.2.1.210 firmware on both Orbi devices. Orbi router cpu at 17%. A...
- Feb 04, 2019
I happened to have a Linksys 1GB switch without any Green stuff or Loop detection. It works OK. I will keep an eye on the network to see is anything changes. The Orbi CPU utilization is about the same at 17%. I might be chasing shadows with the Cisco - it likely is thinking it is detecting a loop when none is actually there.
Feb 03, 2019Guru - Experienced User
Can you remove this particular switch from the mix and try a different switch by chance as a quick test?
I believe this switch may have Green Ethernet which some others have said doesn't work well with Orbi systems.
RPIvers wrote:
Using a Cisco unmanaged sg112-24 switch with Orbi AC-3000 and with one satellite connected via ethernet backhaul to same switch. V2.2.1.210 firmware on both Orbi devices. Orbi router cpu at 17%. All seems fine connection and speed-wise. However, the Cisco switch is indicating a loop on the port where the Orbi router is connected (flashing amber). Orbi router is connecred at 1000/Full.
I am concerned about excess traffic on the LAN because of the suspected loop. If I was not using the Cisco switch I would be none the wiser about a loop because most swtches don't provide that indicator.
Comments?
- RPIversFeb 04, 2019Aspirant
- FURRYe38Feb 05, 2019Guru - Experienced User
You might check the Cisco switch to see if you can disable any of the loop detection and Green Ethernet, then maybe you can still use that switch.
Glad the other switch is working though. Please mark your post as solved so others will know for future reference.Enjoy. :smileywink:
